This is my first post so hello everyone.
I'll start off apologising if this has been posted before, I've looked but come across anthing as yet.
I'm wanting to map my MAudio Axiom49 keyboard with Virtual dj Pro6, Ive gone into the config menu and then to remote section for the midi devices. when trying to map a function I'm only able to map to the active deck,(ie the same slider on my axiom is controling both volume sliders on the mixer, this means i can't fade one in whilst fading out the other) it's not giving me the option to map deck 1 and deck 2 like previous versions. Also there's no invert option, this was useful when using the pitch slider.
I saved my configurations from Vdj5 can I load these into vdj6, if so, how?
thanks
skratchwiz
thanks
skratchwiz
geposted Sat 11 Jul 09 @ 2:21 pm
have you try to buy a legal license. i can see you have a pirate version.
1. buy it
2. you get all the help we can give you.
1. buy it
geposted Sat 11 Jul 09 @ 9:17 pm
I've downloaded the demo not a pirate copy!!
I'm not going to buy if i can't fix the problem.
geposted Sun 12 Jul 09 @ 6:09 am
1. buy it
1. buy it
Dear DJ azen,
We appreciate that you want to protect VirtualDJ but we have a special department in charge of cracked versions and it's not you job to tell if yes or not he has a "pirate version".
Thank you for your understanding.
geposted Sun 12 Jul 09 @ 6:21 am
To make an action specific to a deck, simply add deck 1 or deck 2 in front of the action, e.g:
deck 1 volume_slider
geposted Sun 12 Jul 09 @ 1:20 pm
Thanks i've now got it work. :-)
geposted Mon 13 Jul 09 @ 3:57 pm
moderation staff wrote :
1. buy it
Dear DJ azen,
1. buy it
Dear DJ azen,
of course i understand. no problem at all.
and skratchwiz i give an apologize if i was mean to you.
geposted Mon 13 Jul 09 @ 6:12 pm
