I've been waiting to see what comes new in vdj 6.XX and all that I see is a change in how the keyboard shortcut is configured. I don't like that at any bit. Or if there's something I missed, then somebody should help me immediately. I've been raising money now to come for the version 6.0.1 and to my surprise, the trial version was very dissapointing. Please any advice!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
Monarch say so!!!
Monarch say so!!!
geposted Mon 13 Jul 09 @ 6:44 am
Buy a working keyboard or stop using speed.
geposted Mon 13 Jul 09 @ 7:16 am
Monarch say so!!!
Monarch say so!!!
Sorry that you feel this way about v6... personally i think the new way of configuration is for the best..
The way of configuration (mapping) was changed to allow users flexibility and specificity in mapping their controllers for use with Vdj.... (whether keyboard, or otherwise) and these actions can be set up in many different ways including.. key learning, action writing, and taking action from the skin itself.
I recommend that you spend a little bit more time on the new version in terms of configuration.... and also... get guidance from us on these forums.....we are always willing to assist....
Once you understand the mapping concepts.. then i am pretty confident that you will be liking v6 as i do... pretty soon....(personally i think this version is the best yet)
geposted Mon 13 Jul 09 @ 7:35 am
That's exactly the point of the new version. Inspite all the possible problems you may have, the result is for the best.
As far as the user who was dissapointed with the new version, you could stay on the 5.xx for a liitle while if you don't want to spend not even a minute to set up a few things.
geposted Mon 13 Jul 09 @ 12:12 pm
