Open Virtual DJ
Config > Remote Control > Click General MIDI > Active > Click Again > Config >
Now You Can Change or Assign Button that you want to use on 6 button RMX Console
Example:
On General MIDI Config > Click Add > Effects > Effect_Activate > then hold what button you want on 6 Button RMX Console
there you go
(that's the only i know about 6 button, i still figure it out how to use 6 button or change the other RMX Console Button)
HeHeHe
Other DJ here Cant Give Exact Tutorial How To Configure Or I cant See Some Answer...
Have Fun Mate
Peace Out!!!
Filipino DJ
DJ Tunying
Example:
there you go
HeHeHe
Have Fun Mate
Peace Out!!!
Filipino DJ
DJ Tunying
geposted Mon 13 Jul 09 @ 10:33 am
Your procedure is for version 5.x, correct?
geposted Mon 13 Jul 09 @ 8:39 pm
yap and i see that in other "forum" website not here.. you can do same thing on VDJ 6.0 they call it mapper, but for me is easy to change the button on 5.2.1 and i still can do remix
i install the VDJ 6 and try use it, my console doesnt work and i try to configure nothing happen,
VDJ 5.2.1 is much better for than 6.0
geposted Fri 17 Jul 09 @ 7:29 pm
