Hello,
What I need for using the touchpad for effects like kaoss pad?
I tested a demo and its like dont works.
Also, what effects can I test?
I need this to work for purchase a license.
Thanks
Thanks
geposted Mon 13 Jul 09 @ 2:26 pm
v6 allows you to map the controls on the xponent yourself. You'll see TOUCHPAD_X and TOUCHPAD_Y. Map these to whatever you wish to control, for example effect slider 1.
geposted Mon 13 Jul 09 @ 7:02 pm
Hello,
Thanks for your reply.
Could I make with touchpad coordenates this effect: http://www.genuinesoundware.com/?a=showproduct&b=39
What license I need to buy for using with xponent?
Thanks
Thanks
geposted Tue 14 Jul 09 @ 1:44 pm
