hi am running M-audio Connectiv sound card with Virtual DJ one mixer and CD players but sometimes i get bad sound when playing a song sounds bad ?????
do i have to change any setting ?????
Am running WIN XP PRO
Service Pack 2
1.6 GH 100GB of Ram
NEED HELP THK??????????????????????????
Service Pack 2
1.6 GH 100GB of Ram
geposted Mon 13 Jul 09 @ 5:32 pm
Never seen a computer with 100GB of RAM, unless it was a fileserver. Is this possibly a typo?
What are your current settings under config-->performance?
geposted Mon 13 Jul 09 @ 6:41 pm
sound card = latency 512 (11ms) safe mode (check is ON ) Overclock ( check is ON )
Scratch = Quality is (Check is ON ) Enhanced Algorithm / Filter Size : 11
48khz < - > 44khz = Lowpass Filter (Check is ON ) / Filter Taps : 11
Master Tempo = Advanced ( Check is ON ) Complexity = 0 / Spatialization + 0
geposted Mon 13 Jul 09 @ 8:37 pm
Are you using ASIO or WDM (Simple)?
If not using ASIO, try disabling Safe Mode and see how you get on.
If using ASIO, set your latency to auto and see how you get on.
HTH :)
HTH :)
geposted Mon 13 Jul 09 @ 8:39 pm
I have 1.60 GHz 0.99 of Ram and 100GB hard drive
ASI0
geposted Mon 13 Jul 09 @ 8:40 pm
Turn off master tempo and filter
geposted Mon 13 Jul 09 @ 8:41 pm
I use m-audio conectiv and cdj's1000........
Uncheck safe mode and overclock
Master tempo change it to fast
Also change your sound card latency in VDJ to Auto close VDJ and change your buffer in the conectiv soundcard panel to 256 (from your computer control panel not vdj) if 256 is too low than try the next buffer size...i believe is 384.
With your specs i believe you can run your latency lower than 512.
Good Luck
geposted Mon 13 Jul 09 @ 8:46 pm
Sorry Am New To This Where Can I Find = Master Tempo and Filter
geposted Mon 13 Jul 09 @ 8:47 pm
Now when i load A track it starts at the End of the Track Y ????????????????
And When I Have it in automix they all skip to END of the track
geposted Mon 13 Jul 09 @ 9:15 pm
Go to the info tab an use the restore to factory settings
geposted Mon 13 Jul 09 @ 9:20 pm
As an experiment, go to config-->performance tab, change performance slider all the way to the left, set latency to auto, uncheck safe mode and overclock (as SBDJ has said), change scratch to "latency" and check "simple algorithm, and test that configuration for a while.
You might also consider increasing the RAM in your machine. I started with 512MB and had issues with a 1.6gHz CPU. However, since upgrading to 2GB RAM, I have had few problems with audio quality, depending upon settings, of course.
geposted Mon 13 Jul 09 @ 10:10 pm
