I have the same issue if I'm using TCV or TCCD. I set everthing up and it works well for a bit and then it stops controlling the music playing. If I hold the vinyl or the platter on my cdj1000 I can see on the screen that the spining table has stopped moving and if I backspin I can also see that on screen, however the song does not react to what I'm doing. Not sure if this is making sense. It's frustrating
VDJ 5.2
Hercules RMX
Numark TT ( serato code )
Pioneer CDJ 1000 ( VDJ code on cd )
VDJ 5.2
Hercules RMX
geposted Tue 14 Jul 09 @ 9:53 am
your not registered so if yoru using a trial version it stops responding to TC after a few minutes. if your using a cracked version then guess what. thats another problem with the bootleg copy. spend the $250 and you wont have any problems like MANY others.
geposted Thu 16 Jul 09 @ 5:39 am
hes using vdj
geposted Fri 17 Jul 09 @ 10:56 am
it's not a cracked version. I was a registered user.
Thing is that it works and can see the small turntables react to what I'm doing on with the TC but the song does not. I'm sure I'm not the only one that this happens to.
geposted Fri 17 Jul 09 @ 4:19 pm
try hitting play on the skin while the deck is moving.
geposted Fri 17 Jul 09 @ 4:32 pm
I've push play on the controller and that doesn't help, I"ll try it on the skin
geposted Sat 18 Jul 09 @ 12:11 am
