I want to know how 2 fix a pitch problem. when i load a song the pitch is in the middle wen i load another song in the otha deck the pitch sometimes goes up n down n after that every song that i load does the same. How can i keep the pitch the same all the time? Im runnin the virtual 6.0
geposted Tue 14 Jul 09 @ 7:28 pm
Sounds like the beatmatch issue on another post.
https://virtualdj.com/forums/112447/PC_Version_Technical_Support/VDJ_6_0_1_BUG_thats_NEEDS_to_be_fixed_NOW______SOLVED_.html
Are you changing the volume using buttons in front of your notebook? If so, they are mapped to turn this feature on. Try pressing the "B" key to see if it stops.
If it does you might want to un-map the letter "B" so you can use your volume buttons.
Robert
Robert
geposted Tue 14 Jul 09 @ 11:47 pm
