I have just installed VDj 6 trial and when I load a song to the deck the song position bar doesn't load until the song has been played from beginning to end and if I skip through it it leaves parts blank. This happens with all songs whether they are 2-3 mins or 10-20mins long and analysed or not and is a huge inconvenience when trying to make cue points and such. My pc setup is a Core 2 Duo 3.0Ghz, Asus P5Q Pro mobo with 4gb of ddr2 ram and I am running vista home premium however I have not yet installed any service packs.
Any help would be much appreciated.
Cheers
Ollie
Cheers
Ollie
geposted Tue 14 Jul 09 @ 7:55 pm
Problem is now solved. The quality was set to highest and the max load at lowest so changed the max load to highest and the quality to lowest and it worked fine, then changed the quality back to highest and it works all good :)
geposted Tue 14 Jul 09 @ 8:26 pm
