Does anyone know of a CD ripper that will rip a CD as one long track? I tend to use Mastermix Grandmaster CD's when i first start a night while the pub/club is quite empty, but I'd like to play them through VDJ instead of the CD decks.
geposted Wed 15 Jul 09 @ 11:46 am
You can do that right from VDJ. Either as a wav. or mp3 file.
geposted Wed 15 Jul 09 @ 12:34 pm
How? I can only drag the tracks onto the decks one at a time, or record from the line-in. I can't see any other way to record, I have VDJ ver. 6.0.1 Pro
geposted Wed 15 Jul 09 @ 12:42 pm
cdex is your friend
geposted Wed 15 Jul 09 @ 4:25 pm
I usually use Audiograbber and I just found the way to do it using that thanks.
New problem though, I've ripped a Mastermix Grandmaster Album fine, I've loaded it into VDJ and I'm setting the Cue points for each track so I know what's coming. However, the waveform will only display 10 cue points? I can set cue points 11,12,13 etc but they don't show on the smaller waveform preview, is there a way to show them on there?
geposted Wed 15 Jul 09 @ 5:01 pm
I'm guessing that you want to mix and entire cd and have it as one continous track. Open VDJ, go to the record tab, go into config, and choose mp3 or wav. Line in and set where you want to the file saved and record that way. Another option is to put a mixed cd into your laptop click on the drive, drag and drop the songs over to the right panel in your browser and use the automix feature. For a premixed cd just choose automix type as none. Or drag and drop any music over to the right panel and try automix from there. That's what I do for about the first 30-45 minutes when things are slow.
geposted Wed 15 Jul 09 @ 5:05 pm
i love automix for the start of events or even bathroom/bar runs. no worries about the music cutting off cause your in the pisser.
geposted Wed 15 Jul 09 @ 6:19 pm
