every time i download virtual dj 6.0 to my xp and try to intall it tells me could not initialize installation. file expected=21113513, size returned=6840484. whatts this mean i realy need some help i have a gig coming up and i really need to fix this
geposted Wed 15 Jul 09 @ 2:42 pm
disable antivirus during install.
geposted Thu 16 Jul 09 @ 4:54 am
i uninstalled and re installed VDJ 6, and want to use both the MK2 and rMX controller at will. But everytime I put either of the two in the usb port my computer says (Controller has not been detected) Please help!!!
geposted Thu 16 Jul 09 @ 7:58 pm
No need to double post Blaqside, specially in threads that are not specifically related to your problem.
In anycase, have you first verified that either console is installed correctly, as explained in the following document:
http://ts.hercules.com/faqs/eng/her_eng_00265.pdf
Are you using the latest driver (2.HDJS.2009) for the consoles, and the latest update for VDJ (6.01) ?
geposted Fri 17 Jul 09 @ 9:34 am
