Hello
I want a skin in 1680x1050 with those components.
2 x Pioneer CDJ-400
1 x Pioneer SVM-1000 Mixer
and the other components from VirtualDJ6
the video function, scratch and mix modus in the middle.
If someone had an idear to complete or optimate the skin, I`ll be very happy.
Thanks for everything
Chris
2 x Pioneer CDJ-400
Chris
geposted Thu 16 Jul 09 @ 2:53 am
you would need a 22in monitor to use this, with a resolution of 1920x1080.
not much room for the browser.
geposted Thu 16 Jul 09 @ 7:15 pm
@marksmolinski
Thanks for the answer. But it ist not all right, what you say about my skin.
Right:
I have a 22" monitor as second monitor on my notebook.
It works with 1680x1050, and it looks good.
Ok, 1920x 1080 would be better
Wrong:
The picture in the forum from my skin is in original 1680x1050. I could send it to you, and then you would see that it isn`t to small....
but thanks for the comment.
Greetings
chris
Right:
Wrong:
Greetings
chris
geposted Fri 17 Jul 09 @ 1:56 am
Hi, to be honest, im busy with several other skins.
If someone else wants to pick this up then by all means.
If noone has touched this in the future, i'll take another look at it..
my largest screen is a 32in LCD TV pannel that can do a theoretical 1920x1080, but some of the desktop is just off the edge of the screen!
its better set to 1824x1028, but as the pannel is only 720pits not best viewing 1080i desktop on it.
A nice new 22in monitor is on my wish list :)
geposted Fri 17 Jul 09 @ 7:39 am
Some 17" screens can do 1920x1200, my laptop does, makes for fantastic uncluttered skins. Yet I still seem to run with absolutely minimal function!
geposted Sat 18 Jul 09 @ 8:47 am
Hello friend I am interested in this skin which you can download
is equal to this(Pioneer DVJ 1000 + SVM 1000)
geposted Tue 18 Aug 09 @ 6:34 pm
esse cdj 400 da imagem da lindoo.
nao tem ele para download??
geposted Thu 29 Oct 09 @ 8:08 pm
Orkut had one person who edited the xml file, maybe she can help, remember seeing in the community of virtual dj
geposted Fri 30 Oct 09 @ 3:55 am
ima start workin on that one
geposted Sun 20 Jun 10 @ 4:06 pm
the only change im making to that one is taking away the two extra eqs that are unecessary aka useless
geposted Sun 20 Jun 10 @ 4:12 pm
Hi
Ok ´, zwei Eq´s sind vielleicht unnütz, aber es ist nunmal so, beim SVM 1000. Und ich wüsste nicht was man sonst dort integrieren könnte...
Viel lieber und wohl einfacher als dieser Skin, wäre mir einfach die bestehenden CDJ2000 Skins einmal mit und einmal ohne Video 1650x1080 mit dem Player CDJ400 zu ändern. Der Rest könnte komplett so bleiben...
Gruß
Cw
Gruß
Cw
geposted Wed 23 Jun 10 @ 4:49 am
Hi
Gruß
Cw
Hi
Ok, 4 EQ´s could be useless. But it is so in the Pioneer SVM 1000. And I don´t know what i unstead the eq´s should be implentate.
But could someone change me the two CDJ2000 skins ( one with and one without video ) in CDJ400 Player. Resolutin could be the same in 1650x1080.
Greetings
Chris
Gruß
Cw
Hi
Greetings
Chris
geposted Wed 23 Jun 10 @ 8:52 am
hi
Here are two example´s from the two CDJ2000 skins. Could someone change me the player into an CDJ-400.
Resolution: 1650 x 1080
With Video:
https://virtualdj.com/addons/10311/Pioneer_CDJ-2000.html
Without Video:
https://virtualdj.com/addons/10801/Pioneer_CDJ-2000___DJM-800_(1650x1080).html
Many Thanks:
Chris
With Video:
Without Video:
Many Thanks:
Chris
geposted Thu 24 Jun 10 @ 2:37 am
This is not how we treat users here!!!! If you have nothing nice to say then don't say it at all. You have to remember we have users here from all over the world.
geposted Fri 25 Jun 10 @ 5:47 am
Oops sorry...yeah users with no licence! its summer and everybody wants to be a Dj...Jeezz!,at no charge even!! ha! yeah Right!! " y si no te gusta" I challenge you to a battle on the Tables,any time and any Place !!..."comprende?" Nice skin btw !!
geposted Fri 25 Jun 10 @ 8:26 pm
Its all good bro, we are all a family here however disfunctional we are:)
geposted Fri 25 Jun 10 @ 9:16 pm
No problem... Im sorry I went off, I Run into too many Challengers in the streets And the internete is no diferent...go on with your conversation gentlemen...
geposted Fri 25 Jun 10 @ 11:30 pm
Has anybody got a skin for the Denon DN-HD2500. I can't find one anywhere
thanks
thanks
geposted Fri 02 Jul 10 @ 7:54 am
Hey plz can you give me some lisences ? i have downloaded virtual dj and i love this programm but i can't dl skins ! :(
it says : Your current licenses do not allow you to download Skins
geposted Mon 07 Mar 11 @ 11:55 am
only pursaching a license of this website, you can download skins, plugings
geposted Mon 07 Mar 11 @ 11:59 am
