Hello everyone.
Ever since I started using VDJ I'm had my ICDX's. . . . Apparently Numark and their infinite wisdom decided to stop making the ICDX's. What I loved about VDJ and the ICDX's is that they are mapped within the program. All I had to do is pick my controller and all the mapping was done.
Some of my buttons have been sticking on my players. Should I purchase two new ones before I can't find them anywhere or wait and see what they will come out with? If I wait, how long will it be until there's mapping done for the players. . . I like the "pick your controller" and be done with it option.
thanks in advance for the replies.
geposted Thu 16 Jul 09 @ 1:16 pm
you have to use the mapper funktion in vdj6
but at the moment it is not so smooth like it was in vdj5
there are still some problems in the handling with the new version but they are in the troubleshooting process so stay tuned it will be fixed im sure
until that its better to stay at 5
best regards dj-agua
geposted Thu 16 Jul 09 @ 5:12 pm
ICDX is Problem in all the versions till V6, and that problem makes them useless ,we have been reportin this problem ,they keep circle the answer,some say they work fine, but those who say that they havent answer back with their set up some are blamemig at the mapper,but that is an excuse. I sugest to have this player move from the VirtualDJ Publicity. Sorry for those who are buying the shouldnt be foolin people please ,I will sell them! but I never gonna recomend people that they work with virtualdj.
geposted Wed 09 Sep 09 @ 4:35 pm
@ Jeremy, hang tight. I bet we will see an iCDX II sometime in the next few months. Of course we will see it, and have to wait six months for public sale...but I bet we get a preview soon.
geposted Wed 09 Sep 09 @ 5:08 pm
whats everyone crying about the icdx's? i have a pair and they work great with vdj. i moderately scratch on them. You can't perform all scratch techniques but basic stuff is good. ideal with cd backup
geposted Wed 09 Sep 09 @ 9:34 pm
I agree with I_rids.
Or are we just the lucky ones that doesn't have issues with it.
iCDX is simply just met my djing needs.
geposted Thu 10 Sep 09 @ 2:49 am
OK, please tell me your exactly set up system etc and your icdxs firmware, and if you play full 5hour gigs or more, (I play every fridays and sats, I was using them before BUT I was exposed to have that problem, and HAPPEN to me several times in the course of my events.
geposted Mon 14 Sep 09 @ 10:56 am
Sony Viao: 1.76GHz,2GRAM,XP (Audio only)
2 x iCDX: v0.44FM,HID (side by side with TCV) (update from v0.40 but never seen much difference in performance)
2 x TT200 + M44-7 + VVTCV (not really used because iCDX can handle the job easily)
1 x Audio8 or VV box
Live gig duration: 6hrs straight once a week
Software:VVv5.2.1
With Audio8 i need to install GLI due to the power supply sensitivity of this soundcard.
I think 6hours once a week is not enough though, don't you think?
Well i just can't count how many hours i'm using these set up during free time though, sorry.
Software:VVv5.2.1
geposted Tue 15 Sep 09 @ 3:25 am
I can't remember the firmware version I'm using but I know its not the latest.... I took the approach of if its not broke why fix it. how do you check the version again?
I havent gig tested v6 yet but I was having platter issues up until 6.02 which is now fixed.
v5.2.1 is the one I've been using. Gigs twice a week normally 4-6 hrs each.
Acer with media centre edition. 2gig ram dual core centrino. 256mb dedicated ati vid card. Nothing special in comparison to what's out there. I got probably the last laptop before they changed to the express slot. I use pcmcia audigy card i think. hard to remember... i bought it ages ago.
geposted Mon 21 Sep 09 @ 2:27 am
Thanks guys for the feedback!!
geposted Sun 27 Mar 11 @ 5:28 pm
