Ok now i am down to 20 minutes of good audio before the sound goes bad... I have not installed anything other then VDJ 6.0.2 beta, in the last couple of weeks so i have no idea what is causing this... Ive since uninstalled VDJ hoping that this would solve the problem but it has not... Is there anything special i need to know when uninstalling VDJ?
Today i learned that when the sound turns distorted, i can open sound set up and click on Driver 1 and that will clear it up, i dont even need to go into performance setting to make the audio go back to normal... Also, i learned this only happens on the deck playing; if i start another song in the next deck and mix over, the sound will be fine... I then can open preferenses and click Driver 1 to get everything back to normal...
What sucks is, today while djing poolside the audio would turn bad every 20 minutes... I timed it using my I-phone stop watch...
PLEASE PLEASE PLEASE
Somebody help me....
Again, it only happens when using the headphone settings in the audio set up...
geposted Thu 16 Jul 09 @ 3:07 pm
HELLO????
geposted Mon 20 Jul 09 @ 10:56 am
That's an interesting point. I will investigate in this way.
geposted Mon 20 Jul 09 @ 1:01 pm
Thank you!
geposted Tue 21 Jul 09 @ 4:24 pm
