selecting a song in a player you need to drag and drop.(or use the hdc buttons).
can we make a shortcut for this.
i know that the enter will do this to but that is just a little different than what i mean...
geposted Wed 06 Apr 05 @ 7:52 am
see what you mean....
BUT, you would at LEAST have to select a song that you wanted to play... right?
And when u have selected a song, its ONE button to push to load it to a deck... correct?
You have 2 different Hercules buttons - one load button for each deck
Or, pressing enter at keyboard
How would a shortcut (one key) make it "shorter"? You still would have to select your song...
Sorry, if i did not see your point :)
geposted Wed 06 Apr 05 @ 1:22 pm
you missed it...
what i mean is this.....now i have to stop one player first before loading a song,otherwise it will drop the new song into the playlist.
i don't wanna use the console...
and enter will drop it into the playlist...
now..you know what i mean?...
thnx for reply anyway....
geposted Wed 06 Apr 05 @ 1:27 pm
ah.... sorry... see what you mean
My mistake ;) it will put it in playlist if song is playing for sure
Maybe if there was a keyboard macro that could be :
1. stop song on deck 1.
2. load song from brownser
But the #2 dont excist i think
the console buttons will work, but you dont wanna use them u say ;)
geposted Wed 06 Apr 05 @ 1:37 pm
yess...
in the future i wanna remove the hdc..so i need another shortcut for that.
all other key's are on my keyboard. only this can't be done..
maybe it's something for the "New features" topic...?
geposted Wed 06 Apr 05 @ 3:50 pm
for sure ;)
would like to see that as a new feature
geposted Wed 06 Apr 05 @ 4:51 pm
#2 use: browser_open() for that ;-)
geposted Thu 07 Apr 05 @ 2:43 am
what do you mean djcel?
geposted Thu 07 Apr 05 @ 8:06 am
Remember my post :
He found #2 ;)
the keyboard shortcut you need for your wanted action ;)
Do this :
1. Add a keyboard shortcut to a key (say the letter "M), that STOP song in deck 1
(desk control > stop > deck 1)
2. Add a keyboard shortcut to the SAME LETTER, that opens a new song to deck1
(brownser > brownser open > deck 1 w/value 1)
Voila! ;) you got what u are looking for :)
He found #2 ;)
Do this :
geposted Thu 07 Apr 05 @ 8:15 am
this works......very cool..
thank you guys...
thank you guys...
geposted Thu 07 Apr 05 @ 8:19 am
I say it again.... keyboard macros is a powerfull tool :) for hidden "features" and possibilities of VDJ :)
If you want new song to AUTOPLAY, you can add another function to the same key (#3)... that starts playing the song... etc ;)
geposted Thu 07 Apr 05 @ 8:21 am
I tried adding the #3 to the same letter
- start playing song
damn ;) pretty cool function
ONE key stops old song, loads new, and starts playing it :)
so thanks to you too, djjb :) I got a new COOL keyboard shortcut now :)
geposted Thu 07 Apr 05 @ 8:26 am
