I'm finding that when I start playing with samples, and then start playing songs quite often the two decks start using autopitch with each other. I can't seem to reset it back. Now, none of the samples are on autopitch.
When I look at config it says autopitch matching:disabled.
So, how would I solve this problem? It's very annoying having to exit and then go back into the program to reset whenever this happens.
Thanks so much in advance :)
geposted Fri 17 Jul 09 @ 7:26 am
