Bought the Dj Console RMX 45 min ago and it is not workin the way i want it to.
I have the latest MacBook Pro OSX.
I installed everything and started VDJ and the window error in sound driver appears, and theres not comin any sound what so ever.
I tried downloading VDJ 5.22 bu still the same prob...
What to do??
What to do??
geposted Fri 17 Jul 09 @ 10:17 am
It's a problem that appeared with the last version of OS X (10.5.7).
Simply download and install the latest driver for the Rmx (v1.36) to correct the problem:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=215&cid=1
geposted Fri 17 Jul 09 @ 1:14 pm
Try this, it works for me:
You simply have to choose the "4-out card" in the soundcards, and then selects the Hercules RMX in the field "driver 1", and then I select the output channels as "Master: chan 1&2 Headphones : chan 3&4"...
And then it works just fine !
http://it.virtualdj.com/forums/96662/MAC_Version_Technical_Support/Error_in_the_sound_driver__VDJ_PRO_5_2_1___Hercules_RMX___SOLVED_.html
geposted Sat 18 Jul 09 @ 12:30 pm
