Hey Guys
Sorry if this has been asked before but I just hooked up my VCI-300 to the new virtual DJ and it works together only for play and pause. Anytime I turn the wheel, it pauses the music on the computer and the pitch doesn't work from the mixer.
Thanks alot for your help in advance
geposted Fri 17 Jul 09 @ 11:09 am
Hi Frostdude.
I use the VCI-100 and am very pleased with its operation once I learned how to tweak all the buttons, knobs, & sliders. Go to your config and select Mappers. If you can't figure this out, chime back in.
Jim
Jim
geposted Fri 17 Jul 09 @ 4:11 pm
Could you help me out with it ? What are the suggested settings ?
geposted Sun 19 Jul 09 @ 10:54 am
First are you a registered user ? And what verison of VDJ are you using?
Version 6.0.1 has the easiest way to get the VCI-300 operational. There is a user interface in the "Mapper" section of config that allows you to program all the controls on the VCI. I use the VCI-100 and I learned how to configure all my knobs, sliders, and buttons. I didn't like the native controller settings so I tweaked what I needed to get the functions I required.
If you have an older version of VDJ you have to use "General MIDI" in the config and tweak the controls using XML code. Just a bit more difficult, but learnable.
Jim
Jim
geposted Sun 19 Jul 09 @ 2:32 pm
As a registered user you can download my VCI-300 mapper from the download section. I had some problems in the beta phase so the standard mapper of the v6 have some bugs - sorry for that.
Greetings, Heiko
P.S: It is not a problem of the mapping, instead it's a definition problem - that file has included in release of v6.0 so you can not change it.
Greetings, Heiko
geposted Mon 20 Jul 09 @ 3:20 am
Yes I have version 6.0.1 and it works together ok except when I touch the jog wheel, it stops the music. And the pitch doesn't work
geposted Mon 20 Jul 09 @ 3:04 pm
