K i just bought the virtual vinyl for numark and in doing so just found out how much the mac side is ignored. I am really pissed/disappointed because i wanted the multi instance skin, which is only for pc, and the scratch video, only for pc, the tK filter only for pc, and alot of other stuff i wanted to download and its not for mac!!! WTF! ... so i guess what i am asking how long will it be before i can get these things for the mac version of virtual dj? will virtual dj 6 maybe help bring about some of these effects/skins? and if you know got to get any of the effects or skins i named please help me out, thanks
geposted Fri 17 Jul 09 @ 6:53 pm
Most plugins and skins are created and contributed by talented users of VirtualDJ.
If the creator does not own a Mac or does not have knowledge of Mac programming, there will be no Mac version.
Plugins for PC cannot work on a Mac and vice-versa because the code is different.
Skins can be more readily converted, but often require adjustments due to differences with fonts, etc. If you have access to a PC, simply install the PC skin on it and then copy the skin's .ZIP file from My Documents\VirtualDJ\Skins across to your Mac.
geposted Sat 18 Jul 09 @ 1:21 pm
thank you for the help and info i will try that, i also just thought of getting boot camp for my computer would boot camp enable to download and run windows versions of virtual dj and there skins??
geposted Sat 18 Jul 09 @ 3:25 pm
Yes... it will;)
geposted Sat 18 Jul 09 @ 3:30 pm
Can someone make the show your logo video effect for mac please
geposted Tue 18 Aug 09 @ 12:29 am
yea it IS sad...I like the app but VERY disappointed in the variation from the PC to Mac.
geposted Tue 18 Aug 09 @ 9:45 pm
To be accurate, there is no variation between the PC and Mac versions...not much anyway. It's not in any way Virtual DJ's or Atomix Productions' fault if plugin-creators won't develop their plugins for both platforms.
To make the excisting PC-plugins work with Mac is nearly impossible, or would at least require tremendously impractical trickery. It's unreasonable to blame Atomix Productions not having the foresight to choose a platform-independent plugin-format years ago back when VDJ was still PC-only.
geposted Wed 19 Aug 09 @ 6:22 am
