Even though virtual vinyl does not work with vista 64 bit yet due to driver issues...
I downloaded the trial version finally with the intention of purchasing the software this week.
Like I already mentioned, I have a 17" HP laptop, a behringer DDm 4000 mixer, and two pioneer 1000MK3's and one U control uca202. (not going to use the xp laptop i just purchased till later)
two quick questions for you experts:
1. to practice and get an idea of virtual dj's timecode response, is it possible to hook one of my cdj's up with that behringer ucontrol uca202 ?
2. if so, should i buy another one and can you tell me exactly how to connect my equipment up with the items I have? and if i do use two of those behringer uca202's will that work also for video?
man....i am excited to try this out but would love the chance to mess with the timecode.
help a brother out.
thanks in advance, guys.
help a brother out.
geposted Sat 18 Jul 09 @ 3:03 am
You can use a UCA202 with a single timecode deck.
I wouldn't however personally use two UCA202's as you'd need to join them using something like ASIO4ALL since you can only use a single device in ASIO mode (needed for timecode).
You can do video with any sound setup :)
geposted Sat 18 Jul 09 @ 5:24 am
