Ok guys i have found yet another problem with the tc and vdj 6.0.1.
Last nite at a gig i pressed the sound effect button on my tc and it stopped the music on deck 2.
This has happerned several times now when i use the sound efect and sampler buttons it will stop one of the decks playing.
Has any body else had this problem or no what could be causing this problem
geposted Sun 19 Jul 09 @ 1:02 pm
im runing into something like it to. i get my tc set up an i tweek one of the knobs on my hercules rmx and my sound distorded and the tc
track gets alll jumpy. if theres a way i can go back to the old version where u can automaticly set up the tc that be greate
its taking me too much time to set up over and over.
geposted Sun 19 Jul 09 @ 3:57 pm
i had this problem with button 2 doing the same thing. musics playing on both decks you hit the effect active button and after it stops the effect both channels stop. for me it did it with the TC or with the keyboard shortcut. i emailed numark and got you have apparently found a bug with the software blah blah blah. with no real answer. it wouldn't do it every time the same time it was whenever it felt like it. so i stopped using the effects. then a while later i started giving them a "try" and they didn't do it anymore. since then i have switched to a zero4 still using the keyboard shortcut for effect active on deck b and it (knock on wood) hasn't happened since. i have no reason as to why it changed.
geposted Sun 19 Jul 09 @ 6:26 pm
so is this a bug with vdj or my total control because when i was using 5.2.1 with my tc it worked flawless
geposted Mon 20 Jul 09 @ 3:46 am
i don't know i only used it with cue 5.2 and when i test with vdj 6 it hasnt done it in a while. sorry i can't help further.
geposted Mon 20 Jul 09 @ 1:33 pm
This is a bug in VDJ and will be addressed in a future VDJ update and Cue 6.
geposted Thu 23 Jul 09 @ 6:29 am
