I see that the sonique plug-in isn't available for the Mac, but need to find a good plug-in to use for files that don't have videos. Anyone with good suggestions? I see the clip bank and slide show, but do they both use images and/or videos?
geposted Sun 19 Jul 09 @ 7:34 pm
I bought a visualization DVD and Shadow dancers, ripped them and loaded them on the clip bank plug in. Make sure you configure the video tab to run the clip bank plugin when you play audio.
geposted Mon 20 Jul 09 @ 1:19 pm
What type and where did you get the visualization DVD? And can you put another JPeg or text over it?
geposted Sat 25 Jul 09 @ 11:53 pm
There are quite a few companies that sell them. I use Motion Loops. They are used with clipbank not slideshow. Look for loopable visuals and then check the bpm tab in clipbank so they run with the song. No you cannot put text over the visual with the mac version. The mac will not support the text function. You can make up pages in a different program and use them in slideshow. (ie welcome class of 1980 or bride and groom with the date of wedding) Hope this helps.
geposted Wed 29 Jul 09 @ 2:22 pm
