I have been using version 1.09 that came with my Hercules console, i share a house and the computer some idiot "upgraded" to version 2.? the update I think was a cracked version that does not seem to work with the console?!?! I uninstalled it and put back the free version that came with the console, everything is fine now, but what if I buy the latest version will it work or has this idiot destroyed my registry???
Thanks in advance,
¬¬¬¬SI¬¬¬¬
Thanks in advance,
¬¬¬¬SI¬¬¬¬
geposted Wed 06 Apr 05 @ 8:14 pm
The full version should definatelly support your Hercules console. If any issues arrises you can always post in the forums or contact e-service.
Best Regards
DJ White Devil
Best Regards
DJ White Devil
geposted Wed 06 Apr 05 @ 8:57 pm
OK thats sounds good, until then what pluggins, skins, effects can I add to version 1.09, untill I have some money to buy the full version.
I tried installing one of the custom skins and it did not work, any help?
geposted Wed 06 Apr 05 @ 9:10 pm
that much you would have to look into the skins that are compatible with your current version. I know most are compatible with version 2.*
DJ White Devil
DJ White Devil
geposted Wed 06 Apr 05 @ 9:27 pm
