Ok im having a really werid issue. So i upgraded to verson 6 the other day. Looks great although my cdj-400's are acting werid.. Deck 1 which is the left deck and deck 2 which is the right deck swaped all by themselfs? HUH yea is that happening to anyone else? I'd hate for it to happen at a gig that would be totally embrassing.... Please let me know if this has happened to you and if you were able to fix the issue.
P.s also noticed that all the remote options in the config menu are gone where did they go?
geposted Mon 20 Jul 09 @ 5:33 pm
yep happened to me also, just go to the mapper config in VDJ and click the dop down menu where it says "keyboard" and set it to cdj400 then there should be a little box next to where u just clicked on the right hand side........click on that and put a tick next to "reverse decks" :)
hope that helps dude
M
M
geposted Wed 22 Jul 09 @ 4:34 pm
