I've looked and looked in my program files for the skins folder and I can't find it ANYWHERE within the program. Help. Everything works find. I need skin that works well with my eye sight. Not that I need a big letters to use the program its just easier on the eyes when I'm working. Help. Trust me I don't have a skins folder anywhere in the program. Do I create the folder itself and than add my skin to it?
geposted Thu 23 Jul 09 @ 6:57 pm
This is basic Windows knowledge.
THe skins folder on a windows computer should be at..
{user}\My Documents\Virtual DJ\Skins ...
it could be different for MacOS, but for XP and above, it'll be there.
(PS. Please register your serial number in your forum profile to be able to download all the skins)
geposted Thu 23 Jul 09 @ 7:42 pm
** also to find your skins, you could have use windows search..
geposted Thu 23 Jul 09 @ 7:44 pm
Found it!!! Thank you!! Whew!!
geposted Fri 24 Jul 09 @ 2:55 am
