What's up guys....
I just got the Hercules MK2 and I'm having trouble...It seems that both sides of the mixer play at the same time no matter what I do...Like if I try to blend in Deck A with Deck B, both decks will play simultaniously even though the cross fader is all the way to one side...what am I doing wrong? I followed the set up exactly like the set up thread in the tech issues forum...
I have windows XP and I'm using VDJ 5.0
Thanks in advance
Thanks in advance
geposted Thu 23 Jul 09 @ 9:23 pm
Hello,
YOu need to use the original version, not an illegal copy of VDJ Pro. Did you purchase this MK2 brand new? please put your serial number on your serial number in your profile to saw more information about this.
geposted Fri 24 Jul 09 @ 10:47 am
You should try testing with the version that came with the MK2 and see if the unit works.
geposted Fri 24 Jul 09 @ 6:47 pm
