I just used the exact same setup a few weeks ago to great success; however, I just tried it today and I can't get anything to play. Not even the turntables will spin. Another thing I noticed is my saved Playlists are gone. Am I missing something here?
geposted Thu 23 Jul 09 @ 10:08 pm
Bump please
Bump please
geposted Fri 24 Jul 09 @ 9:19 am
HAPPENED TO ME AS WELL TONITE. WHEN I WENT TO CLOSE IT SAID DO YOU WANT TO EXIT WHILE SONGS ARE PLAYING BUT NOTHING WAS MOVING, I GUESS ITS BACK TO VER 5
geposted Tue 28 Jul 09 @ 12:03 am
I tried Ver. 4 from 2006 and it's still doing the same thing. It must be a setting with our Macs? I got it to work by chance the other day by restarting, but that method isn't working now.
geposted Thu 30 Jul 09 @ 8:19 pm
I had this problem once, and by changing the "Perfomance slider" under "Config" to more quality it was fixed.
Hope this helps.
Hope this helps.
geposted Fri 31 Jul 09 @ 2:07 am
Do you mean under Preferences > Performance? If so, I slid it all the way to Best Quality and nothing happened :(
geposted Fri 31 Jul 09 @ 6:38 am
yeah under performance.
That did it for , i slide it to 1 from the end and it start spinning :)
Sorry it didn't work for u :(
geposted Fri 31 Jul 09 @ 8:10 am
