Topic: ANYONE GOT THE BCD3000 TO WORK
i have try everything to get this unit to work in vdj 6.0.1 just tryed the new mapper still nothing.got it to work in most of the other dj software.it look like a soccer game Germany vs France
geposted Fri 24 Jul 09 @ 6:23 am
Download the latest drivers from behringer site for BCD-3000. If you think is about VirtualDJ 6, then use 5.2.1 and try. I knew some users that use BCD-3000 in VirtualDJ 6.0.1 with no issues now.
did this already it should not be this had install mapper and go! vdj need a quick fix asp.
Good pm guys hope you could help me im using bcd 3000 on an imac it works a while but everytime i change a track from itunes it keeps on crashing... it really annoys me coz i need to reopen it over and over again... hope you can help me out please... im using traktor Le 3.3.3.010 version
If you're using your BCD3000 with traktor, I guess you need to address your problem to NI not here.
This site is for the software VDJ, only.
Cheers
it works very good in traktor maybe you doing something wrong i gess and version of traktor LE you got is too old get traktor le 3.4
I think you have a issue with your computer. I had the same issue before. Since I dedicated my laptop to Virtual I don't have a issue at all. I did some tweaks that I found in the forum that help me with the issue. You should try it, reformat your laptop, of course download the latest drivers for BCD3000 in this webpage http://www.behringer.com/EN/Products/BCD3000.aspx and then do these tweaks https://virtualdj.com/homepage/xeon/blogs/1581/Optimizing_the_system_(WinXP).html Do not install any mapper that you find, if you are using the Virtual DJ 6.0.xx you should be fine.
