Hello, I recently purchased a nrumark stealth control, and want to program my own controls. I'm having problems though. For instance, a free-floating knob that i'd like to use for effect par 1 (i'd like to use the knob to adjust the parameter as smoothly as you can with a mouse) just jumps around when I assign it... no fluidity at all Turning it to 'relative' and setting a really night number for "relative" helps some (lets me move the parameter in the program), but with NO accuracy at all. Also, the track select knob only works in one direction (down), not up. How do I change these, so that a free-turning knob is +1 in one direction, and -1 in the other... because seemingly, this isn't the case.
geposted Fri 24 Jul 09 @ 8:38 pm
This works fine when i assign the effect param to a knob that isn't free floating, but not a free floating knob.
geposted Fri 24 Jul 09 @ 8:41 pm
Why not try the VDJ 6 demo it has the unit already mapped and better support for midi generally.
geposted Sat 25 Jul 09 @ 4:20 am
