I installed the latest drivers of hercules dj console rmx (4.6.3.0) and i have a serious problem since then.Virtual DJ gets stucked for a few seconds when I load a song or by pressing play or stop.I'm sure that the drivers have problem because i tested it to my p.c. and then to my notebook which was working perfect before installing the new drivers.
I asked for the driver version 3.8.0.0 at hercules but they are very late to their answers and services.
So has anyone got the driver version 3.8.0.0 to send me?
Thanks in advance!!
Thanks in advance!!
geposted Sun 26 Jul 09 @ 3:56 pm
I don't, but did you check your origional RMX install disc?
geposted Sun 26 Jul 09 @ 9:57 pm
Yes but i have version 1 and since i have installed the newest firmware the console can't be recognized with this driver anymore.
geposted Mon 27 Jul 09 @ 1:55 am
Out of curiosity, what version of VDJ are you using?
geposted Mon 27 Jul 09 @ 6:37 am
Ok, well this forum is not the best one to use for RMX driver / firmware questions. I recomend you go to the Hercules forums.
http://www.herculesdjmixroom.com/
Allot of the great people on tihs site are also over there.
I believe there is a way to force down firmware if the RMX is not recognised, but I don't know it because I have not asked for it. I would ask over there and sombody should be able to give you the instructions, plus they may even have the driver you want. Either way, that should be a better place to ask because it is run by Hercules and not another company. Take care and good luck.
geposted Mon 27 Jul 09 @ 6:40 am
