Hi there I Just Want to know how can I disabled the crossfader because in th previous version we had this option???
I'm using the xppnent cpontroller and the crossfader is broke so I always had it disabled on Version 5.2 but we the new upgrade don;t know what to do please any help????
thanks in advance
thanks in advance
geposted Mon 27 Jul 09 @ 12:27 pm
It's still there on the options page...
geposted Mon 27 Jul 09 @ 12:31 pm
Yep.
First option, left column I believe ;)
geposted Mon 27 Jul 09 @ 1:37 pm
No is not
not on V6.01
not on V6.01
geposted Mon 27 Jul 09 @ 2:08 pm
djjohan wrote :
No is not
not on V6.01
not on V6.01
Well it should be.
Just looked on mine. You have the Crossfader option top of left column. If you click on the box next to it. You should be able to change to Full, Smooth, Scratch and disable.
Set to Disable and OK it.
geposted Mon 27 Jul 09 @ 2:37 pm
Jimmy I had that option on the previous version 5.2 but not on v6.0.1
I'm not sure this is because I use the MAC version ??????
geposted Mon 27 Jul 09 @ 3:56 pm
Right, OK mate,
I can see you seen this thread on the Mac page.
https://virtualdj.com/forums/113202/MAC_Version_Technical_Support/How_Do_I_disable_the_crossfader_on_VDJ_6_.html
How about creating or trying a Keyboard shortcut for this action. You could try crossfader_curve "disabled" It may work or it may not on the Mac, lol
geposted Mon 27 Jul 09 @ 4:57 pm
