I have just won a pair of Kam DDX5000 turntables on ebay for £70.
These are in like new condition and i just want to no if these will be good for timecode vinyl as i am looking into giving this whole timecoded vinyl stuff a try.
geposted Mon 27 Jul 09 @ 5:01 pm
Bloody bargain mate. They should be fine for timecodes
Any direct drive turntables will do. I would say the most important with timecodes is the Stylus/needles.
geposted Mon 27 Jul 09 @ 5:05 pm
Any turntable works with timecodes. This turntbale looks good and it has a strong motor.
geposted Mon 27 Jul 09 @ 6:46 pm
Thanks guys.
I am thinking of getting the numark cc-1 Cartrides for them will these be ok.
Also what are the best timecode vinyl to us with vdj
geposted Mon 27 Jul 09 @ 7:50 pm
Massive 4.8kg/cm motor torque
enuff said..
enuff said..
geposted Mon 27 Jul 09 @ 9:05 pm
Dont buy the numark needles. Either shure M44-7 or the Ortofon OM scratch needles are good. They have a higher output for a good time code signal.
geposted Mon 27 Jul 09 @ 10:40 pm
I use Stanton Discmaster V3 at home and at the club and I have no problem with them
Alot of people seem to be having success with Serato vinyls over VirtualDJ ones. So I would say give them a try. Plus they are slightly cheaper if you shop around for them ;)
If you do get Serato vinyls remember to use the Noise map timecode engine.
geposted Tue 28 Jul 09 @ 2:56 am
