Hey guys,
So i recorded a half hour mix, and i wanna burn it on cd, but i want to split the tracks so that its not one continuous track playing for 30 mins.
I used to Burn CD feature and split the tracks to about 11 tracks. When i opened the folder where it was saved, i just see a .bin file. now how do i burn this to a cd?
geposted Tue 28 Jul 09 @ 5:38 am
a bin file is an imagefile of the cd . A lots of cd burningsoftware can burn that file . What cd burn software do you use ?
geposted Tue 28 Jul 09 @ 5:48 am
Im using Sonic DigitalMedia. I can burn the file if i select the 'burn data' module in the program. However I can add the file under 'Burn an audio cd' module. Im afraid if i burn it as a data disc it wouldnt be readable from a cd player
geposted Tue 28 Jul 09 @ 10:59 am
I use an old burningsoftware called fireburner but i think a lot of softwares can read and burn Bin/cue files .You can try to convert the bin file to an iso file and burn it with example Nero or maybe your software can handle it .. seach google for "convert bin to iso" and you will find lots of software that fix that
geposted Tue 28 Jul 09 @ 12:02 pm
This program is your friend. http://cdburnerxp.se/
geposted Tue 28 Jul 09 @ 12:19 pm
Yo, Fellas: I just tried the CDBurnerxp File that is posted and i still cannot record my mix to cd. my burner software is the Nero 8 Essentials
geposted Thu 22 Oct 09 @ 4:25 pm
djsonance wrote :
Hey guys,
if you have nero use nero soundtrax
dump the mix into the you can add cd marters in there and also do a cover
geposted Mon 26 Oct 09 @ 4:40 pm
