Is it possible to use the timecoded vinyls with the Hercules DJ console?
geposted Fri 08 Apr 05 @ 12:54 pm
It is possible to use the Hercules buttons. If you ara having the full version you could also use both sound cards, however I do not recommend that while the Asio drivers are crappy.
You need 2 stereo inputs. The Hercules dont have them. So you should buy an additional sound card like the Maya USB.
Ewout
Ewout
geposted Fri 08 Apr 05 @ 1:16 pm
Can I use just one timecoded vinyl? Or does that make any sense?
geposted Fri 08 Apr 05 @ 1:22 pm
not as of now... but might be added in the future as a new feature
as of now, you need 2 turntables
geposted Fri 08 Apr 05 @ 5:59 pm
But you can use DJConsole only as a mixer? Or you have to buy an external?
geposted Sat 09 Apr 05 @ 10:36 am
you can use hercules as a mixer...
geposted Sat 09 Apr 05 @ 5:35 pm
