I have a friend that only has one, count 'em, one CDJ-400. He wants to know how to set up VDJ 6 to control both virtual decks with the one player. I looked but really couldn't find where to set it up that way. It seems to me that I've seen a thread about this but couldn't find it.
Anyone?
Thanks!
DJ RuDe
Anyone?
Thanks!
DJ RuDe
geposted Tue 28 Jul 09 @ 8:20 pm
Sup Rude,
I think is on the sound setup tab, under input choose single timecode.......
geposted Tue 28 Jul 09 @ 9:25 pm
djpr1 wrote :
Sup Rude,
Thanks DJPR, I'll tell him to try it. I have two CDJ-400s so I've never tried it. Are you sure you use the "Single Timecode" setting? I'll check it too when I get back to the studio
Thanks
DJ RuDe
geposted Tue 28 Jul 09 @ 10:10 pm
If he is using it in midi controller mode - All he has to do is press the TAB button to change the active deck
geposted Tue 28 Jul 09 @ 11:05 pm
More what Marcel said. I use the "always" for headphones in the option tab. This way the song automatically loads the into deck and switches the headphones over to the new deck. Then all you have to do is adjust for one deck control with the tab button for affects.
geposted Tue 28 Jul 09 @ 11:33 pm
Is this your final answer!?
geposted Wed 29 Jul 09 @ 1:26 pm
Rude .... I would use a different soundcard in a single setup situation and not use the CDJ400's sound options .... but as a MIDI controller and the default v6 mapping ... pressing the EJECT button on the controller toggles the control between decks ...
Again, I would use a separate sound card and only use the CDJ400 as a controller.
geposted Wed 29 Jul 09 @ 5:40 pm
