i recently downloaded a load of trax from itunes,the problem is,that while 95% of them work fine,there a a few which when loaded up decide to change there pitch completly.
for example,deck A will be pitched at 130 bpm fine,but i load the next track on deck B it's bpm says 191.06??
also i've had it where it says both are in sync on the bpm but the track i want to mix in that i've put on,plays an awfule lot slower and is well out of sync?
i've also had the same problems with trax downloaded from other places.
i'm using my home pc with a numark usb mixer with virtual dj 6.
any help greatly appreciated.
geposted Wed 29 Jul 09 @ 7:09 am
I'd try re-analysing the problem tracks using VDJ and see what results you get.
Also, double check that pitch lock is active and set to zero. This might help.
Finally, if you're a full version user, i'd register the software too...:o)
Good luck and keep spinnin'...(",)
P
P
geposted Wed 29 Jul 09 @ 5:56 pm
