Hi guys,
upgraded to virtual dj 6.0 from virtual vinyl.
when using virtual dj, with the virtual vinyl timecode the bpm value dosent change when adjust the pitch on the decks.
the acutal speed of the song and the waveform image changes, but the actual bpm value stays at the original, if i manually change the pitch in virtual dj itself the bpm changes as normal
it does this in virtual vinyl fine, just not in virtual dj - any ideas?
it just saves alot of time when mixing to get them pretty close with the auto bpm counters first!
thanks
thanks
geposted Thu 30 Jul 09 @ 5:01 pm
oh and key lock was off on the decks :)
geposted Thu 30 Jul 09 @ 5:02 pm
someone has to know guys!
geposted Fri 31 Jul 09 @ 8:09 am
good luck. i posted this when the update came out and i got the tumble weed effect or responses. none. like you said i adjust the pitch via cdj and the pitch on the slider in the program doesn't cahne but everything else does. maybe you'll get an answer unlike me.
geposted Sat 01 Aug 09 @ 2:22 am
sounds promicing . . . is their technical support that bad?
geposted Sat 01 Aug 09 @ 9:53 am
i wouldnt say that i just said i never got an answer on this topic. i never sent in a tech ticket so i wouldn't know about there official tech support. i rely on the boards its usually faster.
geposted Sat 01 Aug 09 @ 9:58 am
Do anyone know how to change the scratch latency in virtual dj 6 the setting are different?
geposted Fri 25 Sep 09 @ 12:32 pm
