I'm having a brain fart and do not have the manual handy...
What is the correct procedure for optimizing the database?
I think I messed up because most of the information for bpm and length is missing from my videos. I think it might have occurred when I did "check" then "fix".
geposted Thu 30 Jul 09 @ 9:36 pm
How about we drain some of the gas from your brain. The manual is always in the same place:
C:\Documents and Settings\YOUR NAME\Documents\VirtualDJ
geposted Fri 31 Jul 09 @ 6:12 am
All manuals available online also: https://virtualdj.com/wiki/PDFManuals.html
I believe the correct order is Fix/Check/Clean ;-)
You might want to check out this thread also: https://virtualdj.com/forums/113070/PC_Version_Technical_Support/PacMan_Database.html
geposted Fri 31 Jul 09 @ 6:20 am
At this point I would suggest copying your target database to a safe location before doing the Check-Clean-Fix procedure. That way you can revert back if the process screws something up.
I am suspicious that the Check-Clean-Fix process either adds space characters or doesn't compact after a record deletion. I have found large holes in the XML databases that will hide your Virtural Folders and perhaps Songs from view due to these gaps.
I experimented and re-edited the XML databases to remove these space characters ... thus manually compacting the info. And restored my hiding VFs.
Be careful and do a backup first.
Regards,
JimL
Regards,
JimL
geposted Fri 31 Jul 09 @ 1:57 pm
Doh! An experienced pro user like myself should have that burned in my brain! Blonde moment hit again I guess.
geposted Fri 31 Jul 09 @ 4:36 pm
