Hi Everyone.
My laptop only has 1 output for sound on it. So I purchased a USB card and installed it.
Now, How do I use the internal soundcard for the main output and the USB card for preview with headphones??? I have tried every combination and the closest I got was using this configuration:
Output: Headphones
Soundcard: 2 cards
Soundcard : Primary sound driver
Second Card: Speakers (USB Audio)
Output Channels: Master first card / Headphones second card
What this does is plays both decks through the main as usual and if you are running deck 1 you can preview a song through the headphones.... BUT if you switch to deck 2 the song on deck 2 (right deck) comes through the headphones WITH the preview song.
Any help would be great!!!!
Im still using 5.2 Just FYI
Thanks a million everyone
Output: Headphones
Soundcard: 2 cards
geposted Fri 31 Jul 09 @ 9:35 am
you got the idea, select usb sound card as main and lappy sound card as headphones
geposted Fri 31 Jul 09 @ 11:19 am
Thanks for the quick reply. That still didnt work. If I do that no mater what side the crossfade is on deck 2 plays.
Any other Ideas?
Any other Ideas?
geposted Fri 31 Jul 09 @ 11:51 am
ok i need a lil more info about your setup like
1 do you have a mixer ?
2 what is the usb sound card (name and type 5.1 or 4.1 in some on)?
this will help us to help you
geposted Fri 31 Jul 09 @ 3:16 pm
i'm not sure as its many years since using a trial version, but seem to remember some fubctions disabled in trial, is this question related to that?
geposted Sun 02 Aug 09 @ 7:40 am
is your outputs set on external mixer ?
geposted Sun 02 Aug 09 @ 5:27 pm
Thanks again.
Here are your questions answered....
I Run through a dj board but for testing Im just using powered pc speakers. 1 set per output.
The USB card is just a 3d sound USB card with 1 output and 1 mic in.
I am not using a trial version. Full Version.
I hope this helps out. I realy want to get this righ before switching to 6.
Thanks again
Thanks again
geposted Sun 02 Aug 09 @ 8:58 pm
