Hi guys,
ive allready got virtual vinyl, with the VV sound card. ive downloaded the trial of Virtual DJ - and seem impressed but..
When using virtual dj - With the virtual vinyl timecode & the VV box - the bpm value dosent change in VDJ when i adjust the pitch on the decks.
The acutal speed of the song and the waveform image changes, but the actual bpm value stays at the original, (when it has clearly changed!) if i manually change the pitch in virtual dj itself the bpm changes as normal, but this isnt any use to me!
the the BPM changes when i use virtual vinyl fine, just not in virtual dj - any ideas?
it just saves alot of time when mixing to get them pretty close with the auto bpm counters first!
im really thinking about upgrading to VDJ pro, so i hope this can be fixed - any help is appriciated
thanks
thanks
geposted Fri 31 Jul 09 @ 12:15 pm
I'm having the exact same issue. I hope this gets fixed soon.
geposted Tue 01 Sep 09 @ 10:31 pm
