Hi Guy's and Gals
When i first bought my RMX I was able to hold down the down arrow button and use the jog wheel to browse through the song list, since the new updates im no longer able to do it, in the manuel its one of the options that you can use
Any thoughts
Thanks
DJ MIkeD
Any thoughts
Thanks
DJ MIkeD
geposted Fri 31 Jul 09 @ 10:04 pm
I can send you my mapper file, just PM me your email. Mine is set so that if you hold the left arrow you browse the tree (folder) window. If you hold the right arrow you browse the song window.
geposted Fri 31 Jul 09 @ 10:07 pm
