im just wondering how do set up the vdj software just playing it continuesly...without openimg the wmp program... i hope u guys know wat im tlking bout...
geposted Sun 02 Aug 09 @ 5:51 pm
All you have to do is put the songs you want to play in the left side list..(you need more then one song)...then press the botton at the top left side of that list and it will ping...try it out.
geposted Sun 02 Aug 09 @ 7:49 pm
make yourself a folder with cocktail music
you would normally only need 15 to 20 songs for an hour , so i don't understand why it needs to repeat
turn on the automix and click the plus sign and select repeat
i think that's what you want .......
geposted Sun 02 Aug 09 @ 8:21 pm
i dont need to repeat the song..i want something like yes...automix..but how do i do that..i want to wander around kinda chit chat with some guess. then later on that evening i can just switch to mixing, without opening another program...
geposted Sun 02 Aug 09 @ 9:22 pm
Just click and drag your song choices into the right column. Up on the top left of that column you will see a circle icon and a + icon. The circle will activate the auto play feature. The + icon allows some different options for this, such as clearing song that were played and such. I dont have VDJ on this particular computer to look at things, but I think it is pretty close to the same for whatever skin you are using.
geposted Sun 02 Aug 09 @ 9:33 pm
