http://www.billfitzmaurice.com/index.html
if you dont know, now you do...
Bills designs are the pinnacle of speaker designs and cost 1/4 the price of the top name brand speakers....
i currently own and built two OmniTop 12's and two Tuba 30's.. and no lie, my system owns all other systems
geposted Sun 02 Aug 09 @ 10:05 pm
I built 2 titan Subs 14" wide and 24" tall with a 10" driver.
Sounds incredible. when placed in a together with a V Plate they are louder, and smoother than any double 18" sub I have ever heard.
There is an Excellent Tutorial for placement of subwoofers to gain maximum performance from them.
http://billfitzmaurice.net/phpBB3/viewtopic.php?f=1&t=398
It talks a lot about Folded horn subs (cause that's what bill likes the most) but I've found that by following the advise in that tutorial with the Bass reflex sub in my B-52 System it has dramatically improved the sound quality of the system
geposted Mon 03 Aug 09 @ 9:18 pm
you use the horns with the b-52 subwoofer?
geposted Mon 03 Aug 09 @ 11:02 pm
No. I use the Horns with other speakers. The B-52 is a complete system it does not require anything else with it.
geposted Mon 03 Aug 09 @ 11:03 pm
oh, ok.. i get what ur saing... you corner place your direct radiating sub to increase spl such as bill recommends you do with horn loaded woofers
geposted Tue 04 Aug 09 @ 8:10 am
Exactly, By following that advise ablout sub-woofer placement I improved the bass to my B-52 system dramatically. Proper sub -woofer placement technique is often overlooked.
Until I read that tutorial and gave what it said a try I would just slap the sub down where ever and crank the hell out of it.
geposted Tue 04 Aug 09 @ 9:19 pm
Just ordered my plans for the Tuba 24's. I plan to build two, will post photos as I progress.
geposted Fri 09 Apr 10 @ 10:41 am
There's a lot more: I builded 4 speakers with a design of Beyma (with Beyma 15" bass-speakers) http://profesional.beyma.com/ingles/recursos.php (just because I already had 4 15" Beyma chassis) and a little (!!) help from http://www.kbapps.com/ . There's a lot of info about cross-overs there.
If you want enclosures designed for the chassis you want check the site of the manufacturer. My latest favorite: Eighteen Sound http://www.eighteensound.com/
Never the less: Usefull topic!!
geposted Sat 10 Apr 10 @ 8:40 pm
Great reading thanks for the tip. I have a question for you Marcel, so when you follow the tip where do you place your tops?
geposted Sun 11 Apr 10 @ 8:09 pm
I place them as wide as Possible. They fill the room better.
Also try and place them As far forward as possible as well, this helps with Mic Feedback (Loud annoying squeal)
geposted Sun 11 Apr 10 @ 8:29 pm
Thanks for that. I will try that setup next time. I too use B-52s tops and folded horns for subs but never thought about placement in this way.
geposted Sun 11 Apr 10 @ 9:39 pm
