Hello,
I am new here so bear with me but loving the forum :)
I am in need of some advice or help with my denon
I have had it 12 months and had no issues- its an american model imported using a uk converter
I am using a self powered hardrive- buffalo- 1tb and have ensured there are not to may files in one folder etc
The issue i have started having is on an intermittent basis the bpm will change mid track- ie i will be in the middle of mixing and the bpm will shift on its own from say 140.0- 140.5- 139.5- this is causing issues in playback making the track "wobble" and making mixing impossible due to the variation in bpm
i am using 100% legal dloads from a website on m03- and am using the deck in single mode not 2 decks in one
I have read through the manual and cant seem to work out whats wrong- buts its really bothering me now
I have never updated the software since i got it would this be worth a try?
Also when i am playing the pitch range button is lit however i am sure that is normal allowing me to adjust the bpm when and if necessary
Thanks for taking the time to read this and thanks for any advice
Wayno
Wayno
geposted Tue 04 Aug 09 @ 3:30 am
