when i hook them up to vdj, it only uses only one units soundcard... how can i fix this?
geposted Tue 04 Aug 09 @ 8:04 pm
ok, i got both cards to work... but now i dont get the displays on one deck...mac
geposted Tue 04 Aug 09 @ 9:35 pm
If you are using VirtualDJ v5.2.1 then only one is natively supported at a time.
If you are using VDJ v6 public beta, make sure that they are both set to MIDI channel 1 and both have the latest firmware installed.
geposted Wed 05 Aug 09 @ 12:08 pm
