Does vdj 6 support Core 2 quad, will use all 4 cores
geposted Wed 05 Aug 09 @ 4:34 am
VirtualDJ is a multi-threaded application so it will take advantage of multiple processor cores.
geposted Wed 05 Aug 09 @ 12:23 pm
We are currently using VDJ with Intel Q9950 & Q6600 Processors and they work perfectly.
geposted Thu 06 Aug 09 @ 7:00 am
Which one is better for VDJ?
2.0 Ghz Quad Core laptop or 2.8 Ghz Dual core laptop?
geposted Fri 18 Sep 09 @ 6:35 am
my opinion, go with the fastest dual core you can afford.
geposted Sun 20 Sep 09 @ 1:03 pm
I have VDJ on my quad core 2.83 in my studio to just play back music here and there. I have nothing but trouble. It shuts down for no reason ect, not 1 problem on my dual core 2.2 laptop.
geposted Mon 21 Sep 09 @ 3:01 am
ok seeing that i do bench marks for pc's the 4 cores or faster just run pc mark and you will see
i had a quad and then went dual im not happy .
as for cooling go with http://www.frozencpu.com/products/9139/lap-51/Lian_Li_NC-09B_17_NoteBook_Cooler_Pad_-_Black.html
its a 220mm 5V fan biger fans make less noise and push more air
geposted Mon 21 Sep 09 @ 6:57 am
