Hi all
Just wanted 2 knw if any1 is using the mk2 as a soundcard for their cdjs or tts with vdj? Hows the sound quality, latency, etc? I'm planning on getting a mk2 and using it as a asio and mixer at a later stage.
geposted Fri 07 Aug 09 @ 12:28 pm
MK2 with its asio driver work very good.
geposted Sat 08 Aug 09 @ 3:59 am
Yes i mostly used the mk2 as my soundcard with cdjs or tts and an external mixer at club and mobile gigs. It is ok and as it is a mid range card..it does do the job well;)
To enhance the quality it is best if you have external audio sound reinforcement unit too and also learn to eq;)
geposted Sat 08 Aug 09 @ 6:40 am
can the mk2 be hooked up to virtual dj using the serato vinyls
geposted Sun 09 Aug 09 @ 9:26 am
Yes you can use seratos time code, you must select it in the config-->Sound Setup-->Time Code Config
geposted Sun 09 Aug 09 @ 10:24 am
ok i did all of that can u plz walk me through the method what to select and all plz
geposted Sun 09 Aug 09 @ 10:31 am
Hello there the timecode now working with my vdj but the timecode is slipping how can i fix this plz help.
geposted Sun 06 Sep 09 @ 9:19 am
Hello djchrisjam,
Is the timecode slipping also if you set the timecode in Absolute mode?
geposted Mon 07 Sep 09 @ 9:24 am
I get error in the asio sound driver when i try to connect my MK2. i dont have a clue what is that. some help
geposted Wed 09 Sep 09 @ 5:32 pm
I dont use the absolute mode i use only the relative mode.
geposted Wed 09 Sep 09 @ 6:24 pm
how do u set everyting. because i keep having the same error with the asio sound driver. i dont know what to do
geposted Wed 09 Sep 09 @ 7:15 pm
Hello djef0407,
If you have a message ' error in the asio sound driver' when you run VirtualDJ, it means VirtualDJ is set in ASIO while the Mk2 is not in ASIO mode.
You should switch your DJ Console Mk2 in ASIO (open DJ Console MK2 control panel, and change the Audio mode from WDM to ASIO) prior to running VirtualDJ.
geposted Thu 10 Sep 09 @ 3:53 am
