Topic: Itunes videoclips not playing
Hi , first of all let me just say that VDJPro is fantastic, the more i get in to the software ,the more i like it, good job from the creators team.
i´m really new at this , and i hope someone can help me here, i´ve been buying tunes and videoclips from itunes , everything was running ok until i notice that some of the videoclips don´t play at all , i try to load them but the only thing that happens is a slim line apearing on the clip monitor, press play but no video or image at all. i open the FILE INFOS on VDJ and i noticed that it shows UNKNOWN KODEC.
can anybody tell me what might be wrong?
am i missing any codec here?
the files info shows an m4v file, all of the other files (videoclips) work fine as m4v files , only four of them don´t, and for my sadness are the ones that i like the best (real annoying no?)
Any help would be nice thanks.
geposted Fri 07 Aug 09 @ 6:42 pm
M4v video files - Even the ones theat are DRM free (itunes+) will not play on anything but itunes and ipods.
To get them to play on VDJ you need to convert them to MP4 video files.
As a Pro user you are able to Download this Tool: https://virtualdj.com/addons/6407/iTunes___Video_Repacker.html
Which is ONLY available to Pro level users. It was generously made available to VDJ users by Andrew87
I have a similar problem. Downloaded the repacker and it found and processed the files. Says it was complete but the mp4 files are empty when I go to access them. Any suggestions?
Check in itunes More than likely the video that are not repacked are DRM protected. (NOT itunes Plus)
itunes plus -DRM FREE- will show up as PURCHASED VIDEO FILE in itunes and the DRM files will show up as PROTECTED VIDEO FILE
The itunes without DRM (itunes Plus) loads well in VirtualDJ 6.x but it's not the case for itunes DRM file (using FairPlay)
