i've looked at the mapper for this button. it doens't exist.
so i've created one: SOURCE = stop.
it functions as stop button, but only after pressing it twice.
1st press goes into denon's source options: pc, etc.
my question is how do i disable denon's menu so it will only function as a stop button. thanks in advanced.
geposted Sat 08 Aug 09 @ 7:51 pm
Unfortunately, you can't disable SOURCE - It is hard-wired by Denon to call up the source menu to switch between connected sources. The same applies for holding down MEMO - It will enter Denon's preset menu.
Both can be MIDI-mapped, but that is in addition to the normal Denon functions.
geposted Sun 09 Aug 09 @ 4:33 pm
