Im using 2 sound cards a onboard soundcard where my headset is plugged in, which im using to preview tracks. And an external 5.1 where my 5.1 speakers are used to hear the track thats playing. The problem is when im trying to play via steromix on the comp its playing the preview track. and not what im hearing on the speakers. Ive swaped the soundcards around threw AtomixMP3 setup and its playing threw Stero Mix fine but I lose the outgoing on the Speakers. So I thought right ill plug the 5.1 speakers into the onboard soundcard and plug the headset into the 5.1 External. But for some strange reason its exactly the same, even if I swap the Soundcards via ATOMIX setup again. IM Baffled any ideas?
geposted Mon 10 Aug 09 @ 10:17 am
Hi DJJLee,
did you really use AtomixMP3 and not your Limited Edition who was brought to you with the Hercules MP3 controller?
Beacuse when you use the LE Version, my first thought was the MIC/CUE Slider on the Skin.
Also it can be, your soundcard setup is wrong.
Can you please post your settings?
Haui
Haui
geposted Tue 11 Aug 09 @ 4:03 am
