I am trying to assign both clone deck and pause active deck as keyboard shortcuts to the same key so that when I press that key, the part of the song that is playing will be cued up on the active deck so that I can play it later when I unpause it. This seems to works fine for songs without cue points that I have programmed, but when I do it on a song with a programmed cue, it will duplicate the deck to the active deck, but pause it at the first programmed cue point instead of the part that was playing. It seems to do this using both play_pause (on active deck) and pause (with a keyboard shortcut for the same key to select the active deck just before pausing) . Any ideas?
Thanks!
Thanks!
geposted Mon 10 Aug 09 @ 4:58 pm
